Keep the spindles turning with Micron Workholding’s Easy Connect!
By Lyndsey Vickers
Are you looking for a quick changeover on your larger workpieces? Look no further than the Easy Connect from Micron Workholding!
Lyndsey Vickers of MTDCNC meets Matthew Jenness of Micron Workholding to learn more about a system designed for very large machine tables and how the solution enables customers to reduce their setup times. Flexible and versatile, the Easy Connect can help you get parts on and off the machine quickly – maximising your expensive machines running time!
