Cutting Titanium with 1 Micron Accuracy Over 3 Metres: Believe It?
Join Tom Skubala from MTDCNC as he interviews Julian Frankland from Ward Hi-Tech about the compact…
Known for solid and reliable cutting technology, these DAHLIH machines at TIMTOS 2023 are worth seeing! Colin Griffiths of MTDCNC and Richard Pearson of Ward Hi-Tech dive into an excellent newly upgraded model fit for all seasons. The VMC 1050 comes as a standard 3-axis with 4+1 and automation capabilities to handle big depths of cut as well as finer machining. Ward Hi-Tech also supply a range of easy-to-program industrial and collaborative automation solutions to complement DAHLIH machines and keep those spindles running 24/7! If you want to get the best of every machining configuration and great cycle time, check out DAHLIH machines supplied by Ward Hi-Tech in the UK.
[ID4115209454]
