TPS360 were contracted by Willmott Dixon to improve an uneven substrate measuring 4,740m² over two floors. Fast setting Remmers Optiplan Base was pumped throughout both areas, using levelling pins to maintain the predetermined datum set by the client. The hardened screed was ready in just 24 hours to begin the final application of Remmers Multiplan SiC.
Benefits
•Fast installation up to 2000m2 a day
•Self levelling
•Fast drying install floor finishes after 24 hours dependent on thickness, ambient temperatures and humidity
• Rapid setting walk on after 2 4 hours under suitable conditions
• Low shrinkage
•Lightweight
•Eco friendly formulation
•High strength >38N/mm2
•Can be polished
•Compatible with all common
floor types
