Okuma Revolutionises Manufacturing with MULTUS U3000 LASER EX
Monday 22 June 2026, 3:38:05 PM
The latest innovation from Okuma, the MULTUS U3000 LASER EX, integrates multiple advanced manufacturing processes into a single machine, offering a groundbreaking solution for the industry. As part of Okuma’s LASER EX series, this machine effectively combines subtractive and additive manufacturing with capabilities including milling, turning, grinding, Laser Metal Deposition, hardening, coating, and heat treatment.
This machine is designed to handle complex and high-value components, allowing for a process-intensive approach that significantly reduces the need to transfer workpieces between separate machines. This integration supports greater accuracy, enhanced throughput, and a more controlled manufacturing process.
Notably, the on-machine hardening feature of the MULTUS U3000 LASER EX is engineered to be faster and to cause less distortion than traditional heat treatment methods. This helps manufacturers improve component accuracy while reducing the overall process time, a key advantage for industries demanding precision and efficiency.
With a maximum turning diameter of 650 mm, a maximum turning length of 1,500 mm, and tool magazine options of up to 180 tools, this machine provides a robust platform for demanding, multi-process production. It is a significant advancement designed to meet the growing needs of the manufacturing sector.
The Okuma MULTUS U3000 LASER EX stands as a testament to innovation in machine tools, promising to streamline manufacturing processes and ensuring high-quality outputs for manufacturers.
View more news from NCMT Ltd
