Zimmermann Inc. Introduces FZU22 Five-Axis Portal Milling Machine for High-Precision Large-Part Machining!
Zimmermann Inc. has introduced the FZU22 five-axis portal milling machine, a high-performance gantry-style machining solution engineered for precision manufacturing of large molds, models and complex workpieces across a wide range of materials and applications. Designed to combine high-speed machining, accuracy and flexibility within a compact footprint, the FZU22 is aimed at manufacturers requiring advanced five-axis contouring and large-format machining capabilities.
The FZU22 features an overhead gantry design that provides stable and precise machining performance for complex components and molded parts. The machine has been developed to accommodate a broad variety of workpiece shapes, dimensions and material types while maintaining high levels of contour accuracy and process consistency.
A key feature of the machine is its specialized five-axis milling head equipped with a 15-kW spindle. This configuration is particularly well-suited for machining intricate contours, deep cavities and tight pockets commonly encountered in large mold and tooling applications. The advanced five-axis capability enables manufacturers to process complex geometries with fewer setups, improving machining efficiency and reducing overall production time.
The machine is supplied as standard with a 24-position automatic toolchanger, allowing rapid tool changes during machining operations and supporting uninterrupted production workflows. For machine control and motion management, the FZU22 is available with CNC systems from either Siemens
