Walter Launches Advanced Carbide Taps for High-Volume, Precision Threading Applications!
Walter AG has introduced two new high-performance carbide taps—the TC180 Supreme and TC280 Supreme—designed to meet the demanding requirements of large batch production and mass manufacturing environments. These tools are engineered to deliver consistent threading quality, extended tool life, and reliable performance, particularly in applications involving high-strength and abrasive materials.
Both taps are manufactured using Walter’s WJ30EL grade, an ultra-fine, highly wear-resistant solid carbide substrate that enhances durability under intensive machining conditions. This is complemented by a HiPIMS (High Power Impulse Magnetron Sputtering) coating, which improves wear resistance, reduces friction, and enables more efficient chip formation. Together, these features contribute to significantly longer tool life and improved process stability, making the taps well-suited for continuous, high-volume production.
A notable feature of these tools is their 6HX tolerance. Unlike standard 6H taps, the slightly increased tolerance—indicated by the “X”—remains within acceptable standards while offering additional benefits in terms of tool longevity. This makes the taps particularly effective when working with materials such as cast iron, steel, and non-ferrous metals, where maintaining both accuracy and durability is critical.
The TC180 Supreme is specifically designed for blind-hole threading applications up to a depth of 2 × DN (nominal diameter). It is suitable for ISO P, K, and N material groups, covering a wide range of industrial applications. The tool incorporates a specialised geometry with varying helix angles, which promotes the formation of short chips and ensures smooth chip evacuation. This is essential for preventing chip congestion in blind holes and maintaining uninterrupted machining. Additionally, the short-chamfered guide section helps reduce stress on the tool, minimising the risk of breakage and enhancing operational reliability. The TC180 is available in metric sizes ranging from M6 to M12 and features an h6 shank tolerance for precise alignment. An integrated axial internal coolant channel further improves performance by facilitating efficient cooling and chip removal during operation.
The TC280 Supreme, on the other hand, is designed for through-hole threading applications, also up to 2 × DN. It is a robust solution for high-speed machining in mass production environments, offering both reliability and efficiency. Like the TC180, it is suitable for steel, cast iron, and non-ferrous materials. The TC280 is available in metric sizes from M6 to M12, as well as fine thread options such as M14×1.5 and M16×1.5, providing flexibility for different threading requirements. It features chamfer form B in accordance with DIN 2197 standards, while the TC180 uses chamfer form C, ensuring that each tool is optimised for its specific application type.
With these new additions, Walter continues to strengthen its portfolio of advanced threading solutions aimed at improving productivity and reducing downtime in modern manufacturing. The combination of innovative geometry, advanced coating technology, and high-quality carbide materials ensures that both the TC180 and TC280 Supreme taps deliver reliable, high-precision results, even in the most demanding production environments.
