Tungaloy Expands DrillMeister Line with Single-Pass Drilling and Chamfering Solution for Faster Holemaking!
Tungaloy-NTK America Inc. has expanded its DrillMeister exchangeable-head drilling system with the introduction of new pre-thread drills designed to perform drilling and chamfering in a single operation. Unveiled at IMTS 2026, the latest addition to the DrillMeister portfolio is engineered to help manufacturers reduce machining time, minimize tool changes, and improve productivity by combining two essential holemaking processes into one efficient machining cycle.
Holemaking is one of the most frequently performed operations in modern manufacturing, particularly in industries such as automotive, aerospace, general engineering, heavy equipment, energy, and industrial machinery. Producing threaded holes traditionally requires multiple machining steps, including drilling, chamfering, and tapping. Each additional operation increases cycle time, requires tool changes, and introduces opportunities for positioning errors or inconsistencies. Tungaloy’s latest DrillMeister solution addresses these challenges by integrating drilling and chamfering into a single-pass operation, allowing manufacturers to streamline production while maintaining high machining accuracy.
The new pre-thread drills have been specifically developed for producing standard tap-size holes, eliminating the need for a separate chamfering tool before tapping operations. By reducing the number of machining steps, manufacturers can shorten production cycles, improve machine utilization, and reduce non-cutting time associated with tool changes and repositioning.
The expanded DrillMeister range supports a broad selection of commonly used tap sizes, including 3/8-inch, 7/16-inch, 1/2-inch, 9/16-inch, 5/8-inch, 3/4-inch, and 7/8-inch holes. This wide coverage enables manufacturers to apply the solution across numerous production applications while standardizing tooling throughout their machining operations.
In addition to the standard drill bodies, Tungaloy also offers modular drill bodies with integrated chamfering capability for applications requiring extended tool reach. Long-overhang machining often presents challenges such as increased vibration, reduced rigidity, and decreased dimensional accuracy. The modular design helps manufacturers maintain machining stability while taking advantage of the productivity benefits offered by single-pass drilling and chamfering.
A major strength of the DrillMeister system is its highly versatile exchangeable-head design. Rather than replacing the entire drill when different hole geometries or materials are required, operators simply change the drill head while retaining the same drill body. This modular approach reduces tooling inventory, lowers operating costs, and significantly shortens setup times between different machining operations.
The DrillMeister platform accommodates a comprehensive range of interchangeable head geometries, enabling manufacturers to optimize drilling performance for a wide variety of applications and materials. Among the available options is the DMP general-purpose head, suitable for everyday drilling applications across multiple material types. The DMC head is designed for high-accuracy machining and incorporates self-centering geometry that improves hole positioning and reduces walking during entry.
For applications requiring flat-bottom holes, Tungaloy offers the DMF head, while the DMH head features reinforced cutting edges that provide greater durability under demanding machining conditions. Manufacturers processing difficult materials such as stainless steels and exotic alloys can utilize the DMM head, which has been specifically engineered for these challenging applications. The DMN head, meanwhile, is optimized for machining non-ferrous materials including aluminum and other light alloys.
This broad selection of interchangeable cutting heads allows a single DrillMeister drill body to perform numerous machining tasks, giving manufacturers exceptional flexibility while minimizing the number of toolholders required on the shop floor.
Further enhancing the system’s performance is Tungaloy’s advanced AH9130 carbide grade, which is available throughout the DrillMeister product family. The AH9130 grade incorporates a proprietary nano-multilayer coating designed to provide superior resistance against several common causes of tool failure, including built-up edge formation, abrasive wear, oxidation, and edge fracture.
One of the coating’s key advantages is its exceptionally strong adhesion to the carbide substrate. This robust bond helps prevent coating delamination during demanding machining operations, allowing the cutting edge to maintain consistent performance over longer production runs. Improved coating durability contributes directly to longer tool life, reduced tooling costs, and more predictable machining performance.
