Trumpf Unveils Next-Generation TruLaser Tube 7000 for High-Performance, Flexible Tube Processing!
Monday 8 June 2026, 12:11:04 PM
Trumpf has introduced the latest generation of its TruLaser Tube 7000 laser cutting machine, delivering enhanced power, expanded processing capabilities, and intelligent automation features designed to help manufacturers improve productivity, reduce operating costs, and achieve higher levels of process reliability. Equipped with 9 kW of laser power and advanced digital technologies, the machine is engineered to address the growing demand for flexible and efficient tube processing across industries such as construction equipment, automotive, aerospace, agricultural machinery, furniture manufacturing, and industrial fabrication.
As manufacturers increasingly seek to process a wider variety of tube profiles, wall thicknesses, and materials while maintaining high productivity levels, laser tube cutting systems have become an essential part of modern fabrication operations. The new TruLaser Tube 7000 has been developed to meet these evolving requirements by combining increased cutting performance with intelligent quality assurance and smart factory connectivity.
One of the most significant upgrades in the new machine is its powerful 9 kW laser source. The increased power output enables manufacturers to process thicker-walled tubes and profiles at higher speeds while utilizing nitrogen as the cutting gas. This capability allows users to achieve cleaner cut edges, improve production efficiency, and reduce overall costs per part. The combination of higher power and optimized cutting strategies helps manufacturers increase throughput without compromising quality.
The enhanced machine design also expands the range of tube sizes that can be processed. Thanks to its larger outer circle capacity of 11.4 inches, the TruLaser Tube 7000 can accommodate a broad variety of profiles and dimensions. Manufacturers can process square tubes measuring up to 8 x 8 inches, round tubes with diameters up to 10.75 inches, and rectangular profiles up to 10 x 6 inches. At the same time, the machine maintains the precision required to efficiently process small-diameter tubes as narrow as 0.50 inches.
This versatility enables fabricators to handle a wider range of customer requirements using a single machine platform, reducing the need for multiple specialized systems and improving overall production flexibility.
Trumpf has also integrated several intelligent technologies aimed at ensuring consistent part quality while minimizing production interruptions. A key innovation is the expansion of the company’s ScanLine technology through the introduction of the Quality Pilot function.
ScanLine uses advanced light-section sensors to measure raw material tolerances and identify deviations in tube geometry before cutting begins. Variations in material quality, shape, or dimensional consistency can significantly impact cutting accuracy and finished part quality. By identifying and compensating for these deviations, the system helps maintain precise machining results.
The new Quality Pilot feature takes this capability a step further by allowing the machine to independently determine when and how often measurements are required. Instead of performing unnecessary inspections on every tube, the system evaluates material quality and automatically adjusts the measurement frequency based on actual conditions. This intelligent approach reduces cycle times while maintaining high-quality production standards.
