Supertec PMGII-100CNC Grinding Machine Delivers Greater Precision and Reduced Cycle Times Through Multi-Process Grinding!
Supertec Machinery is showcasing its PMGII-100CNC universal cylindrical grinding machine, a high-precision solution designed to improve manufacturing efficiency, reduce cycle times, and enhance accuracy for complex grinding applications. Developed to address the growing demand for productivity and precision in modern manufacturing environments, the machine combines multiple grinding processes into a single setup, helping manufacturers streamline operations while maintaining tight tolerances and superior surface finishes.
As manufacturers across industries such as aerospace, automotive, tooling, medical devices, and precision engineering continue to pursue higher productivity and reduced production costs, minimizing machine setups and workpiece handling has become increasingly important. Every additional setup introduces the potential for positioning errors, dimensional variations, and longer production times. The PMGII-100CNC addresses these challenges by enabling multiple grinding operations to be completed in a single chucking, significantly improving process efficiency and part quality.
At the heart of the machine’s design is its turret-type CNC universal cylindrical grinding configuration. The PMGII-100CNC is equipped with three programmable grinding wheels, including a plunge-type outside diameter (OD) grinding wheel, an angle-head OD grinding wheel, and an internal diameter (ID) grinding wheel. This versatile arrangement allows operators to perform a wide range of grinding operations without removing or repositioning the workpiece during production.
By consolidating OD, ID, face, radius, thread, and profile grinding into a single setup, the machine dramatically reduces cycle times while eliminating many of the inaccuracies associated with multiple setups. This capability is particularly valuable for manufacturers producing complex components that require multiple grinding operations and tight geometric tolerances. Completing all grinding processes in one clamping not only enhances dimensional accuracy but also improves repeatability and overall production consistency.
The PMGII-100CNC has been engineered with a rigid ribbed-box machine structure that provides exceptional stability during operation. Machine rigidity is a critical factor in grinding performance, as it directly influences vibration control, surface finish quality, and dimensional precision. The robust machine base helps absorb cutting forces and maintain structural integrity, ensuring consistent performance even during demanding grinding applications.
Further enhancing machine performance is the inclusion of a direct-drive B-axis rotary table. This advanced system provides highly accurate positioning and smooth rotational movement, contributing to improved grinding accuracy and process reliability. The direct-drive technology eliminates many of the mechanical limitations associated with traditional drive systems, enabling faster response times and greater positioning precision.
Supertec has also focused on simplifying machine operation through the integration of its proprietary iGrind graphical conversational interface. The user-friendly control platform is designed to make programming and setup more intuitive, reducing the learning curve for operators while improving overall shop-floor efficiency. The interface supports advanced grinding cycles and simplifies wheel-forming operations, allowing manufacturers to take full advantage of the machine’s capabilities without requiring extensive programming expertise.
The iGrind system supports a broad range of grinding applications, including external diameter grinding, internal diameter grinding, face grinding, radius grinding, thread grinding, and complex profile grinding. This versatility enables manufacturers to process a wide variety of component geometries while maintaining high levels of precision and productivity.
To accommodate diverse workholding requirements, the PMGII-100CNC is equipped with a standard tailstock configuration that supports collet, chucking, and between-center grinding operations. This flexibility allows manufacturers to process a broad range of workpiece sizes and configurations, making the machine suitable for both high-volume production environments and specialized precision machining applications.
The machine’s versatility makes it particularly attractive for industries where component complexity and quality requirements continue to increase. Aerospace manufacturers can utilize the machine for precision grinding of critical engine and structural components. Automotive suppliers can benefit from improved productivity when producing transmission, drivetrain, and fuel system components. Tooling manufacturers can achieve precise profiles and surface finishes required for cutting tools and dies, while general precision engineering companies can leverage the machine’s multi-process capabilities to improve efficiency across a wide range of applications.
Recognizing that manufacturers have varying production requirements, Supertec offers the PMGII Series in five different between-center capacities: 24 inches, 40 inches, 60 inches, 78 inches, and 118 inches. This range of machine sizes allows customers to select a configuration that best matches their specific production needs, from smaller precision components to larger and more complex workpieces.
The combination of multitasking capability, robust machine construction, advanced control technology, and flexible workholding options positions the PMGII-100CNC as a highly capable solution for modern grinding operations. By reducing setup times, improving accuracy, and enabling multiple grinding processes within a single machine cycle, manufacturers can achieve significant productivity gains while maintaining the quality standards required in today’s competitive manufacturing environment.
As production demands continue to evolve, grinding technologies that offer greater efficiency, flexibility, and precision are becoming increasingly important. Supertec’s PMGII-100CNC addresses these requirements by providing manufacturers with a comprehensive grinding platform capable of handling complex workpieces while delivering shorter cycle times, improved repeatability, and enhanced overall productivity.
