RoboDK Launches CAM Software to Simplify Robotic Machining Programming!
RoboDK has introduced RoboDK CAM, a new solution aimed at streamlining robotic machining setup and programming. The software is designed to significantly reduce deployment time for automation projects by enabling users to generate robot programs directly from CAD models and simulations.
One of the key advantages of RoboDK CAM is its ability to eliminate the need for manual programming using vendor-specific robot languages. By automating program generation from design data, the software simplifies integration and allows manufacturers to move more quickly from design to production, reducing engineering effort and potential errors.
The solution supports a wide range of robotic machining applications, including milling, drilling, deburring, cutting, and additive manufacturing. Within a single platform, users can create toolpaths, simulate machining operations, and detect potential collisions before execution. This integrated workflow helps improve process reliability and minimises costly trial-and-error on the shop floor.
RoboDK CAM is compatible with both 3-axis and 5-axis operations, making it suitable for a variety of complex machining tasks. The software is offered in two configurations to accommodate different user needs. A standalone version provides a complete workflow solution, covering everything from toolpath generation to simulation and final robot code output.
In addition, an integrated version allows users to extend their existing CAD/CAM environments. RoboDK CAM can work seamlessly with platforms such as Autodesk Fusion 360, SolidWorks, and Mastercam, enabling manufacturers to incorporate robotic machining into familiar workflows without disruption.
For manufacturers and system integrators, the software offers clear advantages in accelerating automation projects, reducing downtime, and lowering the complexity associated with deploying robotic machining cells. By combining design, simulation, and programming into a unified environment, RoboDK CAM helps bridge the gap between traditional CNC machining and flexible robotic automation.
Overall, the launch of RoboDK CAM reflects the growing demand for smarter, more efficient automation tools that can support the next generation of manufacturing processes.
