Rego-Fix Showcases Swiss-Precision Toolholding Solutions for High-Performance Manufacturing at IMTS 2026!
At IMTS 2026, Rego-Fix Tool Corp. is demonstrating its advanced toolholding technologies designed to deliver exceptional precision, repeatability and reliability for modern machining applications. Renowned for its Swiss engineering excellence, the company is showcasing two of its flagship solutions—the original Rego-Fix ER collet and the innovative PowRgrip toolholding system. These products are engineered to meet the demanding requirements of manufacturers operating in high-precision industries such as aerospace, automotive, motorsports and medical manufacturing, where tight tolerances, superior surface finishes and consistent machining performance are essential.
Developed in Tenniken, Switzerland, the original Rego-Fix ER collet has become an industry benchmark for versatility, precision and dependable performance. Designed to provide exceptional clamping force and superior concentricity, the ER collet helps manufacturers achieve greater machining accuracy while extending cutting tool life. Its broad clamping range allows a single collet system to accommodate multiple tool sizes, reducing tooling inventory without compromising performance or flexibility. Available in various sizes and configurations, the ER collet offers manufacturers a reliable solution for a wide range of machining applications, helping improve productivity while maintaining consistently high-quality finished components.
Complementing the ER collet is the Rego-Fix PowRgrip toolholding system, an advanced press-fit solution designed to maximize rigidity and minimize vibration during high-speed machining. Unlike conventional heat-shrink or hydraulic toolholding systems, PowRgrip utilizes a taper-to-taper mechanical press-fit design that creates a vibration-damping gap, effectively reducing the intensity of vibration waves generated during machining. This results in improved cutting stability, enhanced surface finishes, longer tool life and increased machining accuracy, particularly in demanding high-performance applications.
The PowRgrip system consists of three key components—toolholders, collets and precision press-fit assembly units—that work together to provide a secure and highly accurate connection between the cutting tool and the spindle. One of its major advantages is its remarkably fast tool setup process, enabling tools to be assembled in as little as 10 seconds without the use of heat or hydraulic pressure. Once assembled, tools are immediately ready for machining, eliminating cooling times and allowing manufacturers to maximize machine utilization while maintaining consistent performance throughout production.
Rego-Fix continues to demonstrate the real-world capabilities of its technology through its collaboration with the Ed Carpenter Racing team in the NTT IndyCar Series. As a special attraction at IMTS 2026, visitors can view the team’s race car displayed at the Rego-Fix booth, highlighting the critical role precision tooling plays in high-performance motorsports. By utilizing Rego-Fix toolholding systems, the racing team has achieved exceptional surface finishes, minimized tool runout, extended cutting tool life and reduced machining cycle times while operating at spindle speeds of up to 24,000 rpm. These demanding applications clearly demonstrate the reliability and precision that Rego-Fix solutions deliver under extreme manufacturing conditions.
By combining Swiss-engineered precision, innovative vibration-damping technology and fast, efficient tool setup, Rego-Fix continues to provide manufacturers with advanced toolholding solutions that improve machining accuracy, increase productivity and support the highest standards of quality. Its comprehensive portfolio of precision toolholding systems enables manufacturers across multiple industries to achieve greater process stability, reduce operational costs and confidently meet the evolving demands of high-performance manufacturing.
