Omax ProtoMax Brings Professional Waterjet Cutting to Small Shops, Classrooms and Makerspaces!
Omax Corporation has introduced the ProtoMax abrasive waterjet system, a compact and versatile cutting solution designed to make advanced waterjet technology accessible to smaller manufacturing facilities, educational institutions, makerspaces, and prototyping environments. Combining industrial-grade cutting capabilities with a space-saving design, the system enables users to produce precise and complex parts from a wide range of materials without the limitations commonly associated with conventional cutting methods.
As manufacturers increasingly seek flexible and cost-effective production solutions, compact cutting systems capable of handling multiple materials have become highly valuable. The ProtoMax has been developed to address this need by delivering professional-level abrasive waterjet cutting in a self-contained package that requires minimal installation and infrastructure.
One of the key advantages of the ProtoMax system is its ability to cut virtually any material under one inch thick while maintaining the integrity of the workpiece. The machine can process metals, composites, glass, stone, plastics, rubber, ceramics, carbon fiber, and numerous other materials with high precision. Unlike laser cutting, plasma cutting, or certain machining processes, abrasive waterjet cutting does not generate heat-affected zones, ensuring that material properties remain unchanged throughout the cutting process.
This cold-cutting capability is particularly important for applications involving heat-sensitive materials or components that require strict dimensional accuracy and structural integrity. By eliminating thermal distortion, hardening, warping, and micro-cracking, the ProtoMax provides manufacturers and designers with greater confidence when producing precision parts and prototypes.
Despite its compact footprint, the system incorporates the same core technologies found in Omax’s larger industrial waterjet systems. At the heart of the machine is a powerful 30,000-psi pump that delivers the pressure required for efficient and accurate cutting across a broad range of materials. The system is paired with a precision cutting head and advanced motion control technology, allowing users to achieve intricate geometries and detailed cuts that would otherwise be difficult or time-consuming to produce.
The ProtoMax also features Omax’s IntelliMax software, an intelligent programming platform that simplifies machine operation while maintaining high levels of accuracy and consistency. The software enables users to create and execute complex cutting paths with minimal programming experience, making the technology accessible to engineers, students, fabricators, artists, and hobbyists alike.
Ease of use has been a major focus in the system’s development. Traditional industrial cutting equipment often requires specialized training, extensive setup procedures, and dedicated infrastructure. In contrast, the ProtoMax is designed to be user-friendly and easy to integrate into existing work environments. The machine operates from a standard 230-volt electrical outlet and does not require extensive facility modifications or special installation procedures, significantly reducing setup costs and complexity.
Its all-in-one design also makes it an attractive option for facilities where floor space is limited. The compact footprint allows the system to fit comfortably within small workshops, research laboratories, technical training centers, and shared manufacturing spaces. Additionally, the machine is mounted on casters, providing mobility and enabling users to reposition it as operational requirements change.
The portable design makes the ProtoMax particularly valuable in collaborative environments such as educational institutions, innovation centers, and makerspaces, where equipment may need to be shared among multiple users and projects. By offering industrial-grade cutting performance in a mobile format, the system provides greater flexibility while maximizing the utilization of available workspace.
According to Stephen Bruner, Director of Marketing and Revenue for the Americas at Hypertherm Associates, the ProtoMax was specifically developed to expand access to advanced waterjet technology. He noted that the system enables a broad range of users—including engineers, educators, artists, designers, and makers—to leverage professional waterjet cutting capabilities without sacrificing performance or precision.
Beyond educational and prototyping applications, the system also offers significant value for larger manufacturing operations. Many industrial shops require a dedicated solution for prototype development, specialty jobs, short-run production, and experimental projects that may not justify occupying large production equipment. The ProtoMax provides an efficient way to handle these tasks while allowing primary cutting systems to remain focused on high-volume manufacturing activities.
The growing demand for rapid product development and customized manufacturing has increased the importance of flexible cutting technologies. In sectors ranging from aerospace and automotive to consumer products and industrial equipment, companies are seeking solutions that can accelerate prototyping cycles, reduce production bottlenecks, and support innovation. The ProtoMax addresses these requirements by offering precision, material versatility, and ease of operation within a compact platform.
With its ability to cut diverse materials without thermal damage, its user-friendly software, and its space-efficient design, the Omax ProtoMax represents a significant advancement in accessible waterjet technology. By bringing industrial-level performance to smaller facilities and collaborative environments, the system enables a wider range of users to benefit from precision cutting capabilities while supporting faster innovation, improved productivity, and greater manufacturing flexibility.
