Ocean Machinery Inc. Launches Gladiator Beam Laser for Compact, Multi-Function Structural Steel Processing!
Ocean Machinery Inc. has introduced the Gladiator Beam Laser, a compact structural steel beam processing machine engineered to combine multiple fabrication operations into a single space-saving system. Designed for fabricators seeking high-performance beam processing capabilities without requiring extensive shop-floor space, the new machine integrates cutting, drilling, coping, beveling and marking functions within one compact platform.
The Gladiator Beam Laser has been developed to deliver the operational capabilities typically associated with traditional drill-saw lines and coping machines while occupying less than half the floor space of conventional systems. This makes the machine particularly attractive for fabrication shops looking to maximize productivity and processing flexibility in facilities where available floor space is limited.
The machine is specifically designed for processing structural steel components such as beams, columns, channels and angles commonly used in construction, infrastructure, industrial fabrication and heavy equipment manufacturing. By combining several processing operations into a single machine, fabricators can reduce material handling, streamline workflows and improve overall production efficiency.
At the core of the Gladiator Beam Laser is an advanced cantilever-style structure that travels on precision rails, enabling a narrow and highly compact machine design. This structural configuration allows the system to maintain rigidity and processing accuracy while minimizing the machine’s footprint on the shop floor.
The compact design also supports easier integration into existing fabrication facilities where manufacturers may need to optimize production layouts or expand capabilities without investing in larger production areas. As fabrication facilities increasingly focus on lean manufacturing and space optimization, machines capable of delivering multi-function performance in smaller footprints are becoming increasingly valuable.
The Gladiator Beam Laser is available in three stock lengths — 40 feet, 50 feet and 60 feet — providing flexibility for different production environments and material processing requirements. The system is capable of handling flange heights up to 19 inches and web widths up to 48 inches, allowing manufacturers to process a broad range of structural steel profiles used in commercial and industrial projects.
A key feature of the machine is its ability to cope flush with the inside of the flange, an important capability for fabricators producing cross-members and welded structural assemblies. This functionality helps improve fit-up accuracy and assembly efficiency while supporting more complex fabrication requirements commonly encountered in structural steel production.
The integration of laser processing technology further enhances precision, speed and flexibility compared to traditional mechanical beam processing systems. Laser-based cutting and marking can improve edge quality, reduce secondary finishing operations and enable faster processing of complex geometries and detailed fabrication requirements.
The introduction of the Gladiator Beam Laser reflects growing industry demand for advanced fabrication systems capable of combining automation, precision and production efficiency within compact manufacturing environments. Structural steel fabricators are increasingly adopting integrated processing technologies to improve throughput, reduce labor requirements and enhance overall operational flexibility.
Ocean Machinery Inc. continues to expand its portfolio of fabrication equipment solutions aimed at supporting modern steel processing operations with innovative and productivity-focused technologies. The Gladiator Beam Laser strengthens the company’s offering in the structural steel fabrication market by providing manufacturers with a versatile, space-efficient and high-capability beam processing solution.
As the construction and heavy fabrication industries continue evolving toward faster production cycles and more automated operations, machines such as the Gladiator Beam Laser are expected to play an increasingly important role in helping fabricators meet growing demands for efficiency, accuracy and manufacturing scalability.
