Nissei USA Showcases V-5P Vertical Double Disc Grinder for Precision and High-Volume Manufacturing!
At IMTS 2026, Nissei USA is presenting its V-5P Vertical Double Disc Surface Grinder, an advanced grinding solution engineered to deliver exceptional precision, consistency and productivity in high-volume manufacturing environments. Designed to meet the demanding requirements of industries where dimensional accuracy and superior surface finishes are critical, the V-5P combines rigid machine construction, advanced grinding technology and automation-ready capabilities within a compact footprint. The machine is ideally suited for manufacturers seeking reliable, repeatable grinding performance while maximizing production efficiency and minimizing operational costs.
The V-5P utilizes a vertical spindle double disc grinding configuration that enables simultaneous grinding of both sides of a workpiece. This process delivers outstanding parallelism, precise thickness control and highly consistent surface finishes across a wide range of flat components. By grinding both surfaces in a single operation, manufacturers can significantly reduce processing time while achieving superior dimensional accuracy and repeatability. The machine is particularly well suited for applications where tight tolerances and high production volumes are essential.
A key factor behind the V-5P’s performance is its rigid box-frame construction combined with a high-stiffness spindle design. This robust machine structure minimizes vibration during grinding operations, ensuring stable machining conditions even during demanding production cycles. The enhanced rigidity contributes to improved accuracy, longer grinding wheel life and consistently high-quality finished parts. By maintaining process stability throughout extended production runs, the V-5P helps manufacturers achieve reliable results while reducing scrap rates and improving overall equipment performance.
The machine is configured with a rotary throughfeed carrier system, integrated grinding wheel infeed and carrier oscillation technology, making it highly effective for processing automotive, bearing, transmission and other precision industrial components. These advanced features enable efficient material removal while maintaining strict dimensional control and excellent surface quality. The system supports both conventional abrasive grinding wheels and superabrasive CBN and diamond grinding wheels, providing manufacturers with greater flexibility to optimize grinding processes based on specific material requirements and production objectives.
To further enhance performance, the V-5P is equipped with dual dressing arms for CBN and diamond grinding wheels, ensuring consistent wheel conditioning and sustained grinding accuracy throughout extended production cycles. This capability allows manufacturers to maintain optimal wheel performance, reduce downtime associated with wheel maintenance and achieve shorter cycle times without sacrificing part quality or process consistency.
Designed for today’s automated manufacturing environments, the V-5P also prioritizes operator convenience and ease of maintenance. The machine offers simplified tool changes and easy access to key components, reducing maintenance time and improving overall operational efficiency. In addition, it is fully compatible with automated loading and unloading systems, allowing seamless integration into high-volume production lines and Industry 4.0 manufacturing environments. This automation readiness enables manufacturers to increase throughput while minimizing manual intervention and labor costs.
By combining exceptional grinding precision, robust machine construction, advanced process control and automation compatibility, the Nissei USA V-5P Vertical Double Disc Surface Grinder provides manufacturers with a comprehensive solution for demanding flat grinding applications. Its ability to deliver outstanding parallelism, thickness accuracy and surface finish consistency while supporting high-volume production makes it an ideal choice for companies seeking greater productivity, improved quality and long-term manufacturing reliability.
