Mitutoyo Brings Lab-Level Accuracy to the Shopfloor with Temperature-Compensated Crysta-Apex V Plus CMM!
Mitutoyo America Corp. has introduced the Crysta-Apex V Plus Series CNC coordinate measuring machine (CMM), designed to deliver high-precision measurement directly on the shopfloor without the need for a controlled inspection environment. Built as an evolution of the earlier V500, V700, and V900 models, the new series addresses one of the biggest challenges in production metrology—maintaining accuracy under fluctuating ambient conditions.
At the heart of the Crysta-Apex V Plus is its advanced temperature compensation technology, which enables consistent and reliable measurement even in variable shopfloor environments. Unlike traditional CMMs that require strictly controlled temperatures, this system operates effectively within an expanded guaranteed accuracy range of 15°C to 30°C. This capability allows manufacturers to move inspection processes closer to machining operations, improving efficiency and reducing delays associated with off-line quality checks.
The system’s real-time temperature compensation continuously monitors environmental conditions and automatically adjusts measurement parameters to maintain accuracy. In addition, it incorporates temperature compensation for reference point setting, ensuring calibration stability and repeatability even as ambient conditions change. These features are critical for maintaining precision in modern manufacturing environments where temperature fluctuations are common.
Beyond accuracy, the Crysta-Apex V Plus Series is designed with sustainability and operational efficiency in mind. An integrated air reduction function minimises energy consumption by stopping air supply during standby periods, helping reduce both operational costs and environmental impact. This aligns with the growing focus on energy-efficient manufacturing solutions.
Another key advantage of the system is its near-line measurement capability. By enabling inspection to take place closer to production, manufacturers can achieve faster feedback loops, quickly identify deviations, and make real-time process adjustments. This leads to improved workflow efficiency, reduced scrap rates, and enhanced overall productivity.
The Crysta-Apex V Plus effectively bridges the gap between laboratory-grade precision and shopfloor practicality. It allows manufacturers to maintain stringent quality standards without the constraints of a dedicated inspection room, making it particularly valuable for high-mix, high-precision production environments.
With its combination of advanced temperature compensation, energy-efficient design, and flexible deployment, the Crysta-Apex V Plus Series reflects Mitutoyo’s commitment to supporting modern manufacturing needs. It provides a robust solution for companies looking to enhance quality control, streamline operations, and adopt more sustainable production practices while maintaining the highest levels of measurement accuracy.
