Hypertherm Associates Launches Powermax33 XP Plasma Cutting System with Greater Power, Portability and Precision!
Hypertherm Associates has introduced the Powermax33 XP, a next-generation air plasma cutting system designed to deliver enhanced metalcutting performance, improved portability and superior cut quality across a wide range of industrial applications. Engineered for versatility and durability, the new system combines high cutting power with user-friendly operation, making it suitable for both workshop and field environments.
The Powermax33 XP has been developed to address the growing demand for compact yet powerful plasma cutting solutions capable of handling thicker materials while also providing precision cutting for thinner metals. According to Hypertherm Associates, the system delivers cutting performance comparable to certain 45-amp plasma systems despite its lightweight and portable design.
One of the major highlights of the Powermax33 XP is its ability to provide high-quality cuts across varying material thicknesses. The system offers a recommended cutting capacity of 13 mm (0.5 inches) and a severance capacity of up to 20 mm (0.75 inches), enabling users to cut thicker metals efficiently while maintaining clean and accurate edges. This capability makes the machine suitable for fabrication shops, maintenance operations and industrial service environments where flexibility and performance are critical.
The plasma system also supports FineCut consumables, allowing operators to achieve detailed and precise cuts on thinner materials. This dual capability enables manufacturers and fabricators to use a single machine for both heavy-duty cutting and intricate applications, improving overall operational efficiency and reducing the need for multiple systems.
Designed with portability in mind, the Powermax33 XP weighs just 9.5 kilograms (21 pounds), making it easy to transport between job sites or across the shop floor. Its compact design, combined with simplified controls, enables users to start cutting quickly with minimal setup time. The portable configuration is particularly beneficial for field-service technicians, maintenance crews and contractors who require mobility without compromising cutting power.
A key advantage of the Powermax33 XP is its dual-voltage capability, allowing the system to operate on either 120V or 240V power supplies. This flexibility gives users the freedom to run the machine in a variety of environments, from industrial workshops to remote field locations, without requiring specialized electrical infrastructure.
Hypertherm Associates has also focused heavily on durability and reliability in the system’s design. Built and assembled in the United States, the Powermax33 XP has been engineered to withstand harsh operating environments and demanding industrial conditions. The company says the robust construction helps ensure dependable long-term performance while minimizing downtime and maintenance requirements.
Another significant benefit of the system is its longer consumable life, which helps reduce operating costs and improve productivity over extended use. Longer-lasting consumables minimize replacement frequency, allowing operators to spend more time cutting and less time servicing equipment.
The Powermax33 XP is well-suited for a broad range of industries and applications, including automotive repair and restoration, HVAC and mechanical contracting, metal art and signage fabrication, agricultural equipment maintenance, property and plant maintenance, and educational or technical training programs.
To further reinforce customer confidence, Hypertherm Associates backs the system with a six-year power supply warranty, highlighting the company’s commitment to product quality, reliability and long-term customer support.
With the introduction of the Powermax33 XP, Hypertherm Associates continues to strengthen its position as a leading provider of advanced plasma cutting technology, offering manufacturers and fabricators a portable yet powerful solution for modern metalcutting demands.
