Heule SNAP Tool Enables Single-Pass Front and Back Chamfering for Faster Through-Hole Machining!
Heule Precision Tools has introduced SNAP tooling, an advanced chamfering solution designed to perform front and back chamfering of through-holes in a single machining pass. Developed specifically for CNC machining environments, the system is engineered to improve productivity, reduce cycle times, and maintain consistent chamfer quality in high-volume manufacturing operations.
Traditional chamfering processes often require spindle stopping, reversing, or multiple tool changes to machine both sides of a through-hole. The SNAP system eliminates these additional steps, enabling manufacturers to complete front and back chamfering in one continuous operation. This streamlined approach significantly improves machining efficiency and reduces overall processing time.
The tool operates using an intelligent internal mechanism that automatically controls blade engagement during machining. As the tool advances into the workpiece, the front cutting edge deburrs and chamfers the entry side of the hole. While passing through the bore, the blade retracts safely into the tool body, preventing contact with the hole surface and avoiding potential damage. Once the tool reaches the opposite side, the mechanism reactivates the cutting edge during withdrawal, creating a precise chamfer on the back side of the hole.
This automated operation enables reliable and repeatable chamfering without the need for complex machine programming or additional spindle movements. The system is particularly beneficial in production environments where reducing machining time and improving process consistency are critical.
SNAP tooling is available in standard sizes ranging from 2.0 mm to 35.0 mm, with custom solutions offered for larger diameters. The tooling incorporates durable carbide blades and precision-engineered geometry to ensure stable performance across a variety of materials and machining applications.
A key feature of the system is its patented blade geometry, which delivers burr-free and repeatable chamfers even under demanding production conditions. Coated carbide blades further enhance durability and wear resistance, extending tool life and reducing tooling costs in high-volume manufacturing environments.
The design also simplifies maintenance through a quick-change blade system, allowing operators to replace blades rapidly and minimise downtime between production runs. In addition, cassette configurations are available for integration into multi-tasking tools such as drills and boring tools, increasing versatility and enabling greater process consolidation.
Overall, the SNAP chamfering solution reflects the growing demand for efficient and automated machining tools capable of reducing cycle times while maintaining high quality standards. By enabling front and back chamfering in a single pass, Heule Precision Tools is helping manufacturers improve productivity, simplify machining workflows, and achieve more reliable through-hole finishing operations across a wide range of industrial applications.
