Haimer Introduces Cool-Flash Cooling System to Enhance Coolant Delivery and Machining Performance in Shrink-Fit Toolholders!
Haimer is showcasing its innovative Cool-Flash cooling system at IMTS 2026, introducing a new approach to coolant delivery for shrink-fit chuck applications. Designed to improve heat dissipation, chip evacuation, and machining stability, the Cool-Flash system directs coolant precisely to the cutting edge through an integrated slot geometry built into the shrink-fit toolholder. The solution enables manufacturers to enhance machining performance without modifying existing coolant systems or installing external coolant nozzles.
Effective coolant management has become increasingly important in modern machining, particularly as manufacturers adopt higher cutting speeds, harder materials, and more complex part geometries. Inadequate coolant delivery can lead to excessive heat generation, poor chip evacuation, reduced tool life, and inconsistent surface finishes. These challenges are especially significant in high-precision industries such as aerospace, die and mold manufacturing, medical device production, and automotive engineering, where dimensional accuracy and process reliability are critical.
Haimer developed the Cool-Flash system to address these challenges while preserving the advantages of shrink-fit toolholding technology. Building on the company’s established Cool Jet concept, the new system incorporates multiple precision-engineered coolant slots directly into the toolholder body. These slots channel coolant efficiently along the cutting tool shank, guiding it through the tool’s flutes before delivering it directly into the cutting zone where cooling is needed most.
Unlike conventional coolant delivery methods that rely on external coolant nozzles or additional attachments, the Cool-Flash system integrates coolant distribution within the shrink-fit chuck itself. This eliminates the need for external accessories that may interfere with machining operations or require additional machine setup. The streamlined design simplifies installation while ensuring consistent coolant delivery throughout the machining process.
Another significant advantage of the Cool-Flash system is its compatibility with existing machine tool coolant infrastructure. The system operates effectively using standard coolant pressures of approximately 20 bar, allowing manufacturers to implement the technology without upgrading pumps, plumbing, or coolant delivery equipment. This plug-and-play approach enables machine shops to improve machining performance while minimizing investment costs and reducing installation complexity.
The precision slot geometry has been carefully engineered to distribute coolant evenly around the cutting tool, ensuring that coolant reaches the cutting edge efficiently regardless of machining conditions. By directing coolant precisely where heat generation is greatest, the system improves thermal management during machining operations. Lower cutting temperatures help extend tool life, reduce thermal expansion, improve dimensional stability, and contribute to higher-quality surface finishes.
Efficient coolant delivery also enhances chip evacuation by flushing chips away from the cutting zone before they can accumulate around the tool. Effective chip removal is particularly important during high-speed machining and deep cavity operations, where chip recutting can negatively affect cutting performance, accelerate tool wear, and damage machined surfaces.
These benefits are especially valuable in die and mold manufacturing, one of the primary application areas targeted by the Cool-Flash system. Moldmaking operations frequently involve machining deep cavities, narrow pockets, hardened tool steels, and long-reach cutting tools that present significant coolant delivery challenges. Under these conditions, heat buildup and chip accumulation can compromise machining accuracy, reduce tool life, and negatively impact overall process stability.
By delivering coolant directly to the cutting interface, the Cool-Flash system helps maintain stable machining conditions even in difficult-to-access areas. Improved heat removal minimizes thermal distortion while continuous chip evacuation reduces the risk of chip packing, allowing manufacturers to achieve better surface quality and tighter dimensional tolerances throughout complex machining operations.
In addition to improving coolant performance, Haimer has carefully designed the system to preserve the exceptional precision associated with shrink-fit toolholders. The integrated slot configuration maintains high runout accuracy without introducing imbalance that could affect machining quality at elevated spindle speeds. Maintaining precise tool concentricity is essential for achieving consistent cutting performance, particularly in high-speed finishing applications where even minor runout variations can influence tool life and surface finish.
The system also preserves the slim profile and clearance characteristics of the shrink-fit chuck. Because no external coolant nozzles or attachments are required, the toolholder retains its compact design, allowing better access to confined machining areas while minimizing the risk of interference with workpieces or machine components.
Haimer offers the Cool-Flash cooling system for cutting tool diameters ranging from 6 mm to 50 mm, making it suitable for a broad range of roughing and finishing applications across various manufacturing industries. The wide diameter range enables machine shops to utilize the technology for everything from small precision components to larger industrial workpieces requiring high material removal rates.
As manufacturers continue to pursue higher productivity, greater machining accuracy, and longer tool life, advanced coolant management technologies are becoming increasingly important. Haimer’s Cool-Flash system demonstrates how innovative toolholder design can significantly improve machining performance without requiring major changes to existing machine tools or coolant infrastructure.
By combining integrated coolant delivery, precise thermal management, effective chip evacuation, and uncompromised toolholder accuracy, the Cool-Flash system provides manufacturers with a practical solution for improving machining efficiency while supporting the growing demands of high-performance precision manufacturing.
