Haas Enhances CNC Efficiency with Innovative Offsets
Monday 8 June 2026, 3:41:51 PM
Haas Automation has introduced a groundbreaking solution to streamline the setup process in 5-axis machining, addressing a common challenge faced by manufacturers. The company highlights the Dynamic Work Offset (DWO) and Tool Center Point Control (TCPC) features on their Universal Machining Centres (UMCs).
These innovations are designed to alleviate the time-consuming task of setting up new parts on machining tables. Typically, after posting a CAM program and bolting down the part, users may find discrepancies in the expected position, necessitating program reposting and adjustments. This can lead to significant downtime, impacting productivity.
DWO allows machinists to place parts anywhere on the table while the system automatically adjusts the program to match the part’s position. Additionally, TCPC maintains the tool tip on the programmed path despite the movements of the rotary axes. Together, these features ensure that a single program remains effective regardless of the part’s placement.
For shops using Haas UMCs, utilising DWO and TCPC can significantly enhance operational efficiency. Haas emphasises that failing to implement these tools could result in considerable wasted time.
Haas Automation, a leader in CNC solutions, continues to pioneer advancements that cater to the evolving needs of the manufacturing industry, underscoring their commitment to innovation and efficiency.
View more news from HAAS
