EMUGE-FRANKEN, GibbsCAM and Matsuura to Host Live 5-Axis Machining Demonstration Event!
EMUGE-FRANKEN USA has partnered with GibbsCAM and Matsuura Machinery USA to host a live 5-axis machining demonstration event on May 21, 2026, at the EMUGE-FRANKEN Technology Center in West Boylston. The event is designed for CNC programmers, machinists, and manufacturers interested in transitioning from traditional 3-axis machining to more advanced 5-axis manufacturing processes.
Scheduled from 10 a.m. to 2 p.m., the session will focus on practical methods for simplifying 5-axis machining while helping shops improve productivity, reduce setup times, and increase operational flexibility. The organisers aim to demonstrate how modern machining technologies and software tools can make multi-axis manufacturing more accessible for a wider range of manufacturers.
A major highlight of the event will be live machining demonstrations on the Matsuura MX-330 PC10. The system combines simultaneous 5-axis machining capabilities with an integrated pallet system designed to improve spindle utilisation and minimise machine idle time. The demonstrations will showcase how automated pallet handling can support high-mix, low-volume production environments by enabling manufacturers to manage multiple parts and operations more efficiently.
The event will also feature demonstrations from GibbsCAM, focusing on intuitive 5-axis programming and full machine simulation capabilities. Attendees will see how advanced CAM software can simplify the programming of complex toolpaths, reduce programming time, and improve process verification before machining begins. Machine simulation technology will demonstrate how manufacturers can identify potential collisions and optimise machining strategies in a virtual environment, helping reduce risk and improve production reliability.
In addition to machining and programming demonstrations, visitors will experience the new EMUGE EvoGrip in operation. According to the company, the EvoGrip system provides clamping forces of up to 75 kN while delivering repeat positioning accuracy of plus or minus 0.01 mm. The quick-change clamping design is intended to improve setup efficiency, machining stability, and overall process reliability, particularly in precision manufacturing applications.
The event reflects the growing adoption of 5-axis machining technologies across the manufacturing industry as companies seek greater flexibility, shorter cycle times, and improved accuracy. By combining advanced machine tools, CAM software, and precision workholding systems in a live production environment, the demonstration aims to provide manufacturers with practical insight into implementing efficient multi-axis machining strategies.
Overall, the collaboration between EMUGE-FRANKEN USA, GibbsCAM, and Matsuura Machinery USA highlights the increasing importance of integrated manufacturing solutions that combine automation, advanced programming, and high-precision machining to support modern production requirements.
