Dillon Manufacturing Jaw Forming Rings Simplify Chuck Setups and Improve Machining Accuracy!
Dillon Manufacturing Inc. has introduced its advanced self-centering jaw forming rings, also known as jaw boring rings, designed to simplify chuck setup procedures, reduce installation time, and improve machining precision for turning operations. Engineered for efficiency and ease of use, these innovative workholding accessories help manufacturers achieve more accurate jaw boring while minimizing downtime during machine changeovers.
The jaw forming rings are specifically developed to attach directly to the front of chuck jaws without the need for additional tools. This tool-free installation approach enables operators to complete setups faster and more efficiently, helping shops improve productivity and reduce non-cutting time. By streamlining the setup process, the rings are particularly valuable in high-mix production environments where frequent jaw changes and adjustments are required.
One of the primary benefits of Dillon’s jaw boring rings is their ability to create a jaw surface that remains true to the machine centerline. Accurate jaw boring is critical for maintaining part concentricity and achieving precise machining results, especially in demanding turning applications. By ensuring that jaws are machined accurately in position, the rings help improve gripping performance and overall machining consistency.
The rings are also designed to automatically compensate for “jaw lift,” a common issue that occurs during chuck operation, particularly in older or worn chucks. Jaw lift can negatively affect part concentricity and machining accuracy if not properly addressed. Dillon’s design helps reduce these issues by applying uniform pressure across the jaws during the boring process. This results in more consistent jaw bores and improved part alignment, even on larger diameter chucks or machines that have experienced wear over time.
In addition to enhancing accuracy, the jaw forming rings help extend machine uptime by enabling faster and more repeatable setups. Shops can more efficiently prepare soft jaws, round jaws, and full-grip jaws for specific workpieces, ensuring a stronger and more reliable grip during machining operations. Better gripping performance reduces the risk of part movement, vibration, or inaccuracies during cutting, contributing to improved surface finishes and dimensional consistency.
Dillon Manufacturing offers the jaw boring rings in both diameter-specific and adjustable models to accommodate a wide range of chuck sizes and machining requirements. Diameter-specific versions are optimized for dedicated chuck applications, while adjustable models provide added flexibility by supporting multiple chuck diameters. Both styles are available for chuck sizes ranging from 6 inches to 18 inches in diameter, making them suitable for a variety of turning machines and industrial applications.
The adjustable designs provide an added advantage for shops handling diverse workholding setups, as operators can use a single ring across different chuck configurations. This versatility can help reduce tooling inventory while improving operational efficiency.
Both the fixed and adjustable models feature Dillon’s no-tools attachment system, allowing operators to quickly mount and remove the rings without interrupting workflow. The simple yet robust design supports reliable operation and repeatable performance across repeated setup cycles.
When paired with Dillon jaws, the company’s jaw forming rings are designed to deliver dependable and accurate chuck preparation for a broad range of machining applications. Their combination of setup speed, precision alignment, and jaw lift compensation makes them a valuable addition for manufacturers focused on improving productivity, machining accuracy, and workholding reliability in modern turning operations.
