Baileigh Industrial Launches Gear-Head Engine Lathes Designed for Safer and More Efficient Part Production!
Baileigh Industrial has introduced a new line of gear-head engine lathes engineered to improve productivity, operator safety, and machining efficiency for modern manufacturing environments. Designed specifically for production-focused shops, the new lathes combine robust construction, user-friendly operation, and enhanced safety systems to help manufacturers increase output while minimizing downtime and operational complexity.
The latest gear-head engine lathes are built to support a broad range of machining applications and are particularly well-suited for production and job shops, maintenance repair and overhaul (MRO) facilities, industrial manufacturing plants, fabrication operations, training institutions, and companies looking to upgrade from older manual lathe systems. By integrating practical safety features and productivity-enhancing technologies, Baileigh aims to provide a reliable turning solution that meets the evolving needs of today’s machining industry.
One of the key highlights of the new lathe series is its strong focus on built-in safety and controlled operation. Each machine is equipped with a comprehensive standard safety package that includes a foot brake for rapid machine stopping, a chuck guard for added operator protection, and a lead screw cover designed to reduce the risk of preventable accidents during operation. These integrated safety features help create a safer working environment while allowing operators to maintain productivity with greater confidence.
In addition to operator safety, Baileigh has prioritized workplace cleanliness and operational efficiency. The machines feature a full-length splash guard and an integrated chip tray that help contain chips and coolant directly at the source. This design reduces cleanup time, minimizes shop-floor mess, and helps maintain a more organized and efficient machining environment. Cleaner workspaces can also contribute to reduced downtime and improved machine maintenance over the long term.
The gear-head engine lathes are also designed for coolant-ready performance, with a standard coolant system included to support longer machining cycles and heavier workloads. Efficient coolant delivery not only helps improve surface finishes and dimensional consistency but also extends tool life and reduces wear during demanding machining operations. This makes the machines particularly valuable for shops handling continuous production runs or difficult-to-machine materials.
Another major advantage of the new lathe lineup is its large machining capacity. Core geared-head models feature a substantial 2-inch spindle bore, enabling operators to machine larger stock materials and perform common bar work applications more effectively. This expanded capacity allows manufacturers to take on a wider range of jobs without requiring additional equipment, increasing operational flexibility and productivity.
Baileigh has also emphasized compliance and future scalability in the design of these machines. The lathes feature UL 987-certified electrical safety systems, supporting safer workplace standards and helping facilities meet compliance requirements. In addition, the machines offer upgrade options such as collet closers and taper attachments, allowing shops to expand capabilities as production demands evolve.
To further improve machining accuracy and setup efficiency, the lathes come standard with a two-axis SINO digital readout (DRO) system. This feature provides real-time position feedback, helping operators achieve target dimensions more quickly and accurately while reducing dependence on manual measurements. Faster setups and improved precision can significantly enhance workflow efficiency and reduce production errors.
Beyond the machines themselves, Baileigh Industrial supports customers with lifetime service support and access to experienced local and in-house sales application specialists. This combination of technical expertise, safety-focused engineering, and productivity-driven design positions the company’s new gear-head engine lathe series as a strong solution for shops seeking reliable and efficient turning capabilities in today’s competitive manufacturing landscape.
