Grip-Tec Ltd to Showcase Advanced Workholding Solutions at MACH 2026, in Collaboration with MTDCNC
By Tom Skubala
Workholding is increasingly recognised as a critical enabler of performance on the modern shopfloor. At MACH 2026, Grip-Tec Ltd will demonstrate how advanced workholding strategies are helping manufacturers improve efficiency, precision, and productivity across a wide range of machining applications.
Exhibiting in Hall 20, Stand 310, Grip-Tec Ltd will present solutions designed to address some of the most persistent challenges faced by machinists today, including extended setup times, inconsistent clamping, restricted tooling access, and overall productivity limitations.
Rather than focusing solely on component retention, Grip-Tec’s approach centres on enabling broader manufacturing improvements. Their workholding technologies are engineered to maximise machine utilisation, support automation-ready processes, enhance repeatability, and deliver measurable efficiency gains in production environments.
Visitors to the stand will see how modern workholding systems can play a pivotal role in unlocking the full capability of machine tools. By reducing non-cutting time and improving process stability, these solutions contribute directly to increased throughput and improved part quality.
MTDCNC will be working closely with Grip-Tec Ltd throughout the exhibition to capture and showcase live demonstrations, real-world applications, and in-depth technical insights. This collaboration will ensure that key innovations and practical use cases are shared with a global manufacturing audience before, during, and after the event.
MACH 2026 provides an ideal platform for manufacturers to explore how strategic investments in workholding can drive meaningful improvements on the shopfloor. Grip-Tec Ltd’s presence highlights the growing importance of integrated, performance-focused solutions within modern machining operations.
Event Details:
📅 MACH 2026
📍 NEC Birmingham, UK
📍 Hall 20, Stand 310
For manufacturers seeking to enhance machine performance and operational efficiency, Grip-Tec Ltd’s stand is set to be a key destination at this year’s exhibition.
