What does it take to machine a medical implant with zero room for error?
By Arthur Field
Tuesday 5 May 2026, 12:00:00 PM
When you’re making parts that go inside the human body, you can’t have something out of tolerance. That’s why Donson & Betts treat every step with extreme care, from raw stock to final polish.
Donson & Betts don’t just machine parts — they engineer trust into every component. With high-tolerance machining, smooth handoffs between setups, and the ability to run multiple machines with confidence, they’re proving that accuracy and efficiency can go hand in hand — even when the cycle times stretch into hours.
Watch as Arthur Field of MTDCNC gets the inside scoop from Oscar on how they cut, mill, EDM, and polish each implant to perfection.
