RB50A
Monday 16 February 2026
Supplier Information
RB50A by balance-systems
Automatic and semi-automatic balancing machine for the electric transmission rotors
Features
- Semi-automatic balancing machine able to balance the entire range of rotors for electric motors weighing up to 25 Kg in a completely automatic mode on two planes (dynamic).
- This machine is specifically developed to balance the rotor for the electric transmission on the automotive field.
- The unbalances are corrected by axial drilling to remove material on the lamination stack.
- Loading/unloading of the piece is manual but the machine can be easily equipped with industrial robot or linear pick and place making the RB50A a fully automatic balancing machine.
Advantages
- High level of flexibility
- High measuring precision
- High balancing precision
- Quick production change over
- User friendly
Technology information
| Max rotor weight: | 25 kg (55.11 lbs) |
| Max rotor diameter: | 200 mm (7.87 in) |
| Max stack lamination length: | 230 mm (9.05 in) |
| Cycle time: | 90 s (measuring, two planes drilling, audit) |
| Controlled by: | Industrial PC |
| Drive system: | Loop belt |
| Measuring precision: | 0.1gmm/kg |
| Power supply: | 400 V three-phase 50/60 Hz |
| Machine weight: | 2000 kg (4409 lbs) |
| Machine dimensions (LxWxH): | 2111x1960x2422 mm (83.11×77.16×95.35 in) |
