The cutoff tool that fixed Swiss machining’s weakest link?
By Arthur Field
Predictable cycles, longer tool life, and small parts that finally run the way Swiss machines are meant to!
In Swiss machining, the cutoff is often the problem: wasted material, broken flow, unpredictable tool life. Switching to the Vargus ST Cut lets Resolute Precision Manufacturing cut right at the guide bushing for more rigidity, consistency, and lights-out confidence. Join MTDCNC’s Arthur Field and Resolute Precision’s Brad Werblo to learn more.
