![](https://cdn.mtdcnc.global/cnc/wp-content/uploads/2023/07/17211909/Tungaloy-Instagram-10-700x700.png)
Challenging Long-Reach Drilling Made Easy and Accurate by New DrillMeister’s Modular Drill Bodies
To tackle the challenges of unstable drilling conditions and poor quality holes caused by traditional long-flute…
View productTungaloy has added 0.1 and 0.2 millimeter nose radii to its polycrystalline diamond (PCD) tipped turning insert line with NS chipbreaker, increasing the insert size selections.
For years, high-speed aluminium machining with PCD inserts presented significant advantages, but a chip control challenge persisted – until now. Introducing Tungaloy’s cutting-edge ablating technology, which has enabled the development of our sophisticated NS chipbreaker geometry directly on the PCD tip surface. With a specialised rake face and chip redirector designed for 0.1 and 0.2 millimeter nose radii, the NS chipbreaker guarantees reliable and consistent chip forming and evacuation in all aluminium alloy part machining that spans from finishing to light-roughing operations.
A total of fifteen new 0.1 and 0.2 millimeter nose radius PCD inserts have been added with NS chipbreaker. All new inserts are in Grade DX110. Extremely wear-resistant, this submicron grain sized PCD grade provides the insert with a strong edge security that promotes superior surface finishing quality and process stability. These new inserts are designed to eliminate birdnesting of chips in machining applications with small corners, shoulder fillets, or undercuts requiring 0.2mm or smaller radii. They are also ideal for finishing applications requiring a close tolerance and high surface quality after a light depth-of-cut pass, in which excellent chip breaking and control are vital. Typical part samples include precision aluminium parts for automotive, optical equipment and instruments, and artificial intelligence robotic system industries.
Product information:
