Hydrafeed MSV80 Barfeeder
The MSV80 is a full servo-driven Barfeed eliminating the need for compressed air. Unrivalled performance and…
View productA Master Liner System is provided with every new Barfeed installation.
Each Master Liner System is supplied with black acetal bushings; the bushings are bored with the appropriate clearance of the bar diameter to be run, and are designed to support different bar diameters through the headstock of the lathe.
An alternative option to the Master Liner System is dedicated liners; these are supplied without bushings and the bore of the dedicated liner suits the bar diameter required.
Dedicated liners can also be supplied to suit hexagon, square, rectangular and irregular shaped profiles. The profile bar is orientated by the dedicated liner as it feeds through the headstock to align with the lathe workholding
Features
Benefits.
