MTD Tech Corner | Superior metal removal with ZCC Cutting Tools’ EMP90 system!
By Tom Skubala
Tuesday 16 July 2024, 4:00:00 PM
Are you struggling to get the metal removal you hoped for? Or maybe your machine is not powerful enough to hit those numbers?
Here’s an economical solution: Introducing the EMP09 tangential mounted system from ZCC Cutting Tools!
Whether it’s cost savings or the amount of force you can put through compared to other cutters, these tangential cutters can be used in such a wide range of machines. So if you’re looking to save time and make more money, check out the strong portfolio of tangential cutters from ZCC Cutting Tools to achieve that metal removal rate you’re looking for!
Learn more in this special Tech Corner with Tom Skubala of MTDCNC and David Wilsher of ZCC Cutting Tools.
