How simple is it to run a WEILER machine? Enough to get you cutting in minutes!
When the spindles are turning, you’re making money – and that’s what WEILER is all about! MTDCNC’s Tony Gunn meets Johnny LeFlore of Methods Machine Tools to find out more. Flexible, adaptable, and easy to use, the WEILER E50 brings together German engineering, rigidity, and precision for machining difficult materials. With the ability to run parts of complex shapes and contours and an easy on-board programming system, the WEILER E50 enables machinists to save on time and get more done on one machine. If you’ve got high-mix low-volume work, this amazing piece of technology from Methods Machine Tools can get you up and cutting within minutes!
