Thame Workholding introduce HWR stamping technology – SOLIDStamp
    Workholding
    The HWR stamping technology is known to the market as SOLIDStamp, and it is a process in which a defined tooth contour is stamped into the workpiece in advance under high pressure for subsequent clamping by the form fit. This working step takes place outside the clamping device. With #SOLIDStamp​ from HWR, you create a secure clamping due to established clamping technology. With the help of the stamping station, raw parts can be prepared for clamping in the vice within seconds. Complex pre-machining, such as the milling of clamping points, is no longer necessary. A minimum clamping depth of 3 mm and highest holding forces are only some of the advantages of SOLIDStamp.
    Loading...
    Our Partners
