Shaping Up Hexagonal Forms With NTK
Monday 3 December 2018, 12:00:00 AM
NTK has built an enviable reputation for its extensive cutting tool product lines available particularly for small part and sliding head turning applications. Now, the Japanese high speed tooling specialists have developed a complete line of broaching tools for processing hexagonal holes in components.
The new Shaper Duo addition to the Stick Duo product line has been introduced to machine hexagonal, square and hexalobular forms in turned parts. As part of the extensive NTK ‘Stick Duo’ Series, the solid carbide PVD coated Shaper Duo tool inserts are manufactured to diameters that perfectly fit the vast range of Stick Duo toolholders.
The benefit of the Shaper Duo Series over the commonly used broaching tools is the improved cycle times, reduced tooling costs and the flexibility to produce a complete range of hexagon sizes with a single tool. The hexalobular Shaper Duo tool is offered as a single sided tool with an optimised length of 70mm and a 5mm shank diameter. A multitude of geometry options are available for manufacturing hexalobular socket sizes T6, T7, T8, T10, T15, T20, T25, T27 and T30.
For the provision of hexagonal socket forms, NTK’s Shaper Duo is manufactured as a cost effective and efficient double-sided tool with diameters that include 2, 3, 4, 5, 6 and 8mm and an overall length option of 50, 60, 70 and 80mm. The dimensions of the120 degree point angle tool support the production of hexagonal heads with an across flat (AF) base of 1.5, 2, 3, 4, 5, 6 and 8mm. These seven AF base dimensions enable the end-user to machine hexagonal forms from 1.4mm to 12.2mm AF.
Completing the Shaper Duo line is the double-sided square socket Shaper Duo insert. Like the hexagonal variant, the 90 degree geometry square end tool is manufactured with an overall length of 50, 60, 70 and 80mm with a cutting depth of up to 16mm. With a tool shank diameter and corresponding base AF dimension of 2, 2.5, 3, 3.5, 4, 5, 6 and 8mm, the square socket Shaper Duo cam manufacture precision square socket forms from 1.9mm to 8.1mm with astounding surface finishes inside the form.
Setting up the tool overhang, parallelism and concentricity of the NTK Shaper Duo can be conducted quickly and easily, making the Shaper Duo the ideal solution for producing hexagonal, square and hexalobular forms in turned parts. For further details, please contact NTK Cutting Tools.
