ESPRIT for Profit Unlocks the Full Potential of Tools
Friday 2 October 2020, 9:36:53 AM
ESPRIT for Profit is a new, special edition of the popular software that works for tools which require specific toolpaths generated only with CAM systems.
Montpellier, France (1 September 2020)—Thomas Edison is quoted as saying, “There’s a way to do it better—find it.” This is the continuous challenge in which ESPRIT for Profit was born. Tool manufacturers offer innovative tools with high potential to save time and money and to machine difficult parts and materials. Those tools could be valuable for machine shops. Unfortunately, it isn’t always easy to unlock their full potential.
“ESPRIT for Profit enables production to easily access all the benefits of these innovative tools,” says Luca Ruggiero, Sales Director for EMEA at DP Technology, the parent company of ESPRIT. Offered via yearly subscription, ESPRIT for Profit doesn’t require users to purchase a full CAM system or an extra add-on. ESPRIT for Profit offers the high-speed machining cycle in combination with the standard digital machine package for a very competitive price.
ESPRIT for Profit is available for milling with ESPRIT’s ProfitMilling® cycle or for turning with high-speed cycle ProfitTurning®. The ProfitMilling cycle offers dramatic improvements in cycle time, boasting a reduction of up to 75% compared to traditional milling strategies. It can also extend tool life by up to 500% thanks to a patented method of cycle optimization that produces consistent chip loads and reduced cutting forces. The optimized, high-speed toolpath patterns reduce the need for rapid machine accelerations and abrupt changes in direction, which would otherwise negatively affect chip loads and increase cutting forces. A chip thinning technique cuts at full axial depth and reduced radial width, allowing significantly higher feed rates. To maintain the programmed chip load throughout the cut, the ProfitMilling cycle dynamically adapts the actual feed rate to account for geometry and toolpath variances. Offset, spiraling, and trochoidal motions reduce the need for rapid machine acceleration/deceleration, increasing the overall velocity; therefore, the programmed federate is easier for the CNC to attain and overall removal rates are maximized.
ESPRIT’s ProfitTurning cutting strategy features a toolpath that maintains consistent chip load and cutting forces, allowing for significantly increased cutting speeds. By employing controlled engagement techniques using round inserts, the ProfitTurning toolpath also reduces vibration and residual stresses, making it particularly useful for thin walls or hard materials such as superalloys. This innovative cutting strategy results in significantly reduced machine cycle time and cost per part, allowing for increased productivity. ProfitTurning is the ultimate turning solution with a 25% reduction in cycle time and a 300% increase in tool life compared to traditional strategies.
“There are many very efficient tools on the market. Unfortunately, the tools need to be programmed by a CAM system, so companies must invest a lot in a full system,” says Mr. Ruggiero. “ESPRIT for Profit is the solution for manufacturers to unlock the full potential of their tools at an affordable price.”
About ESPRIT and DP Technology Corp.
DP Technology Corp. is a leading developer and supplier of computer-aided manufacturing (CAM) software. ESPRIT®, DP Technology’s flagship product, ESPRIT®, is a powerful CAM system for CNC programming, optimization, and simulation—supporting the entire manufacturing process. With factory-certified post processors delivering machine-optimized G-code and ESPRIT’s ability to solve unique challenges with automation solutions, ESPRIT is the smart manufacturing solution for any machining application. With world-class technical support, ESPRIT empowers you to get started quickly and keep running at top efficiency. ESPRIT is the only CAM system you’ll ever need.
DP Technology reinforces its commitment to technical excellence by dedicating nearly 20 percent of its annual revenue to ongoing research and product development. This long-term focus has produced powerful technological innovations that have placed ESPRIT in an industry-leading position since its market launch in 1985.
