Ceratizit highlights the latest innovations and deals in its Special Selections publication
Ceratizit UK & Ireland customers will be benefitting from some special introductory offers when they receive the latest edition of the machining specialist’s Special Selection publication. Included is a range of milling, drilling and turning innovations at introductory discounts of up to 30 per cent for orders placed before 30 November 2020.
Among the new products featured is a new standard range of turning inserts targeting the machining of steel components. With standardised geometries and coatings these inserts will provide a first choice for those looking for high performance reliable turning of across a range of standard applications. A wide selection of insert styles and nose radii are available as standard.
Drilling of steel, stainless steel and cast iron is covered by the high performance range of drills with TiAlN coating. These are available in flute lengths ranging between 3x and 12x diameter and diameters ranging from 1.0mm to 20 mm, with through coolant and the choice of HA and HB shanks as standard.
Also highlighted is the range of high performance (HPC) solid carbide milling cutters with their 35/38 degree geometry. Available in sizes from 3mm to 20 mm diameter in two standard lengths, these high performance cutters are suitable for a wide range of applications including side milling, full slot, ramping and helical milling.
To receive a personal copy of the latest Special Selection publication please contact Ceratizit UK & Ireland on 0800 073 2073. Alternatively, it can be found here: https://cdn.plansee-group.com/is/content/plansee/en_9902200499_special_selection_pim
Loading...
