Tungaloy UK has now introduced its latest advanced product offering with a new product campaign that has been presented by Tungaloy Corporation Chairman and President of the IMC Group, Mr Jacob Harpaz. The company’s ADDFORCE global launch introduces the latest innovations in metal cutting tools from Tungaloy. The new products have been developed to improve customer productivity by accelerating machining operations. Jacob Harpaz has undertaken a world tour to present the new innovations with presentations already given to customers in Japan, Asia, Europe and North America. The new ADDFORCE products include the latest cutting-edge technology for turning, milling, grooving and holemaking applications and are destined to build upon the results provided by Tungaloy’s existing product lines. To celebrate the launch of this expansive new range, Tungaloy UK will be running a series of promotions to March 2022.
The promotional opportunities will include a range of discounts and offers on new toolholders and insert ranges that will provide engineers with the chance to witness the benefits that can be yielded from the new product lines. The promotions will cover product ranges such as the new AddForceCut, the AddInternalCut, TetraMiniCut, TungFeedBlade and TetraForceCut parting and grooving series. From the turning portfolio, Tungaloy UK will be offering attractive promotional discounts on the new AH6225, the PS and PM chipbreaker inserts and IsoEcoTurn turning inserts, the MiniForceTurn and TungTurnJet turning lines. From the tranche of new milling products, Tungaloy UK will demonstrate attractive promotions on the new AddDoFeed high feed milling series, the Tung-Tri and TungForceRec shoulder milling line alongside exclusive offers on the extended TungMeister range of interchangeable milling heads and the Drillmeister interchangeable drilling system. As part of this new brand launch, Tungaloy has extended their indexable square shoulder milling system Tung-Tri with the new size 04 insert.
The 04 size has a 3.5mm cutting edge length that makes this new arrival compatible with tool body diameters as small as 8mm. With the 04 inserts available for tool bodies from 8 to 25mm diameter, the small new Tung-Tri 04 insert has a 4mm inscribed circle, yet it delivers the same benefits of light cutting and long tool life that existing Tung-Tri inserts have been providing for manufacturers. This enables the Tung-Tri 04 to generate up to double the tooth density when compared to alternate tools and subsequently increase feed rates. This compact configuration enables a 16mm diameter Tung-Tri 04 cutter to offer four inserts per cutter whereas the 25mm diameter cutter can facilitate six teeth.
This insert density is common throughout the Tung-Tri series, ensuring that all tool body diameters and insert designations can offer maximum productivity levels and feed rates. Complementing the new compact size 04 inserts are tool bodies for size 06, 10 and 15 inserts. The 06 inserts are suitable for 12 to 50mm diameter tool bodies with 25 to 100mm diameter for the size 10 inserts and 40 to 160mm diameter bodies for the size 15 inserts. This expansive range now ensures maximum productivity levels for components that demand high-speed cutting.
