https://cdn.mtdcnc.global/cnc/wp-content/uploads/2021/05/14163130/ByStar-Fiber_8025_open_white_035-640x360.jpg
    Machining
    A new dimension with 15 kilowatts
    • By MTDCNC
    • May 18, 2021
    • 1 minute read
    With a laser output of 15 kilowatts, the new ByStar Fiber cuts steel, aluminium and stainless steel from 1 to 30mm and brass and copper up to 20mm with high precision. This increases the laser power by up to 50 percent and enables sheet metal companies to optimise production processes.
    The 15 kilowatt ByStar Fiber high-end fibre laser provides a reliable cutting process even with the highest laser outputs. The technological leap from conventional 3 to 12 kilowatt systems to the new 15-kilowatt level is tremendous. On average, the 15-kilowatt laser increases the cutting speed of the ByStar Fiber by up to 50 percent (when cutting with nitrogen) compared to a 10-kilowatt laser source.
    The new power level is available for the ByStar Fiber 3015, the ByStar Fiber 4020 and new for the ByStar Fiber 6225 and the ByStar Fiber 8025 machines.
