Lk launches portable arms
- March 18, 2020
- 3 minute read
Manufacturing static co-ordinate measuring machines (CMMs) in the UK since 1963, LK Metrology has now diversified into the supply of 3D articulating arm metrology systems, otherwise known as portable arms.
With the launch of a range of 24 machines called the FREEDOM arm, there is a 6-axis model for touch probing and a 7-axis version for multi-sensor metrology, which also includes laser scanning. Both are available in two accuracy levels and the four products come in six sizes with a reach of up to five metres. Marketing Manager Dave Robinson, who is based at the firm’s CMM factory near Derby, commented: “The solutions we can offer customers is greatly expanded by the new range of arms.
The two 6-axis arms for tactile inspection are named FREEDOM Classic and FREEDOM Select, the former being the entry-level model and the latter the enhanced accuracy version. The addition of an extra degree of freedom provides infinite movement and enables laser scanning with a Nikon Metrology ModelMaker H120, MMDx100 or MMDx200. These 7-axis arms, again in two accuracy versions, are called FREEDOM classic scan and FREEDOM select scan. The touch probing accuracy of all FREEDOM arms is certified to ISO: 10360-12 and can be supplied with a variety of aluminium and carbon fibre probe kits, styli, mounting rings, magnetic or vacuum bases, tripods, rolling stands, and carts with a granite top.
Carbon fibre tubular construction ensures stability under challenging conditions. Infinite rotation and a proprietary counter balance makes manual movements light, which promotes ease of use even when trying to access awkward areas of a component. Wi-Fi connectivity and battery power allow completely portable wireless touch probing for maximum flexibility. The arm can be stowed and locked in place between measurements and when it is being relocated. Even the largest FREEDOM arm model weighs less than 11 kilograms.
A notable feature of the arms is the inclusion of absolute rather than incremental rotary encoders to feed back the angular position of every joint to the control software. The equipment may therefore be used immediately on start-up, avoiding the need to calibrate the probe before use every time.
This raises productivity, as does the highly repeatable probe connection that allows them to be swapped quickly without interrupting the measuring process to recalibrate. A strong line-up of third-party inspection software can be supplied by LK Metrology with its new FREEDOM arms, including InnovMetric’s PolyWorks Inspector, ArcoCAD metrology software from Metrostaff is also available, as is Nikon Metrology’s Focus Inspection for data acquisition and analysis.
