Seeley International is a designer and manufacturer of evaporative cooling products and as evaporative cooling is becoming the most efficient option for cooling large areas – this will be showcased at MACH on Stand 48 in Hall 6.
Traditional air conditioning may not even be an option in warehouses or industrial plants, as the capital and running costs would be extremely prohibitive. Most industries with high heat loads, such as printing, ceramics, glass, rubber or electronics, have no cooling system installed and this impacts the workers’ morale, productivity and health. In these examples, Direct Evaporative Cooling could be the right solution.
Seeley coolers do not use any sort of chemical refrigerants to cool the air, just a pump to supply water to the wetted media where evaporation occurs. A small amount of electricity is required for the pump and the fan that pushes the air inside the building. Evaporative air cooling uses up to 87% less energy than conventional air conditioning. Indoor Air Quality (IAQ) is high on the agenda to maintain a healthy and comfortable environment. Seely products supply 100% fresh filtered outside air; so spaces are effectively being purged when coolers are being used, removing dust, dirt, allergens and airborne viruses.
Perhaps you only have one or two small areas inside the space that need cooling. This is not a problem as ‘spot cooling’ can be achieved with Seely units.
