The Allied Machine & Engineering stand at MACH was a sight to behold and the envy of its surrounding exhibitors. The sports bar theme was a huge success with MACH visitors, and the welcoming surrounding soon had the crowds flocking.
Once on the stand, visitors were engrossed in the latest innovations from the manufacturer of holemaking and finishing tools. A centrepiece attraction of the show for Allied was the expansion of the T-A Pro high-penetration drilling system and the High-Speed Steel geometry insert that is also referred to as the ‘X’ geometry. The Super Cobalt insert works as a diverse drill insert while significantly lowering the risk for high-value components. When functioning in less than ideal conditions, the High-Speed Steel geometry provides superior performance and chip formation in addition to process security when needed most.
With a tool life that rivals carbide, the HSS geometry insert works well in almost every material class and at MACH, Allied Machine’s team of engineers showcased this insert as the simplest solution for selecting a drill insert when hole quality, tool life and process security are the primary needs of the application.
