The biggest Milling Machine at AMB
CORREA showcased the largest machine at the event – the impressive FOX Gantry machine! Lyndsey…
Spanish machine tool specialist Nicolás Correa, in collaboration with its esteemed UK partner DTS UK, is set to make waves at this MACH Exhibition. They unveil the impressive Fox 60, hailed as ‘probably the largest machine at the show’, on Stand 310 in Hall 19. The Fox 60, already purchased by a customer in Carlisle, boasts remarkable dimensions, with X-, Y-, and Z-axis travels of 6,000mm, 4,250mm, and 1,750mm respectively. Featuring a distance between columns of 3,750mm and a generous table size of 6,500mm by 2,500mm, this machine embodies power and precision. Highlighting its capabilities is a 37kW, 1,298Nm torque, ISO-50 Big Plus UAD milling head – a patented Correa universal milling head capable of 6,000rpm. This cutting-edge technology, based on a double Hirth crown, facilitates rotations every 0.02º, ensuring unmatched accuracy and reliability.
