![](https://cdn.mtdcnc.global/cnc/wp-content/uploads/2023/06/07135235/1-700x700.jpg)
GROB G350 (Generation 2) with Automation PLUG & PLAY READY TO GO !
Short availability GROB G350 (Generation 2) with Automation PLUG & PLAY READY TO GO ! HIGH…
View productThe G350 5-axis universal machining center offers customers in the machining industry almost unlimited options for milling workpieces made from a wide variety of materials
Our universal machining center is optimally designed for the multiple requirements of different industries and convinces with its diverse application possibilities.
Our horizontal spindle position enables the greatest possible Z-travel and an optimal chip fall
The unique arrangement of the three linear axes results in a small distance between the guides and the working point (TCP) and a particularly high rigidity of the machine.
GROB tunnel concept enables the largest possible component to be pivoted and machined within the work area without collision, even with the longest tools.
Three linear and two rotary axes enable 5-sided machining and 5-axis simultaneous interpolation with a swivel range of 230 degrees in the A-axis and 360 degrees in the B-axis.
